Lapp’s Cable Glands Deliver Full EMI Protection With Simplified Installation
By Editor | September 28, 2012
Lapp Group’s SKINTOP® MS-M BRUSH is now available in NPT sizes from ¾” to 2”. Previously only available in metric sizes, Lapp’s cable gland enables engineers to address EMI control on the factory floor more effectively than other termination methods, such as the grounding clamps commonly used on drive systems.
The SKINTOP® MS-M BRUSH provides continuous 360° contact around the cable’s screen braid which protects against EMI by lowering the resistance of current ground path and providing a low impedance connection between the cable shield and the housing.
Lapp-Group
Some shielding options have difficult termination methods or grounding connections that can drive up labor cost and time. Lapp’s design addresses this common installation issue by making it easier for engineers and plant managers to create an EMI-free connection between the cable and the SKINTOP® cable gland. Installers simply insert the cable, push the screen braid into the brush and tighten the cable gland assembly. Other grounding methods such as earthing sleeves require far more effort to make the termination.
In addition to its innovative brush-type connection, SKINTOP® MS-M BRUSH offers IP 68 protection and resists temperatures up to 100ºC. Now it is available in both metric sizes, ranging from M–25X1.5 to M–110X2.0 and NPT sizes from ¾” to 2”.
Lapp Group
www.lappusa.com
Filed Under: Cables + cable management, Connectors (electrical) • crimp technologies
Tagged With: lappgroup
molex-versablade-300x300
Heilind Electronics now offering Molex VersaBlade Wire-to-Wire Connector System
bel-stewart-m12xcode-connector
Stewart Connector M12 X-Code PCB mount connectors
Heilind-electronics-product-image
Heilind Electronics now offering Molex PowerPlane BusBar Power Connectors
Harting Technology Group heads for a climate-neutral future with record investment
