This summer, LinkTech Quick Couplings Inc., Ventura, Calif., will be launching two new large flow couplings for the medical market. Available in July, LinkTech will now offer the 60PP Series Large Flow couplings with 3/8-in. flow with both valved and non-valved configurations and the 60PS Series Large Flow couplings, which are produced in high performance thermoplastic Udel Polysulfone material.
The 60PP connectors are manufactured from medical grade, gamma sterilizable polypropylene which allows greater chemical resistance. They come equipped with a larger, more robust thumb-latch as well as a new and improved panel mount that has a stronger more reliable design for thicker wall panels and other various applications.
Also available as 3/8-in. flow size couplings, the 60PS connectors are more durable and stable at higher temperatures. They also offer a new and improved Panel Mount design that has a more reliable, thumb-latch which makes it more durable, easier and faster to use. These couplings, with valved and non-valved configurations, are known to replace brass in pressurized hot water applications with their greater pressure strength and high temperature, autoclave sterilizable material.
Both new series interconnect with all other 60 Series Couplings in the LinkTech Product Range as well as other similar industry high flow couplings. They are available in 50-plus different styles and are reverse field compatible.
www.linktechcouplings.com
The post Large-flow medical-grade couplings appeared first on Connector Tips.
Filed Under: Connector Tips
