EXAIR’s new Type 303 Stainless Steel 3 NPT Threaded Line Vac Air Operated Conveyors convert ordinary pipe into a powerful conveying system for parts, scrap, trim and other bulk materials. This chemical and corrosion resistant Line Vac operates seamlessly at higher temperatures providing a long-lasting and low maintenance solution ideal for food, chemical, pharmaceutical and medical processes. The durable construction of the Threaded Line Vac employs a larger inside diameter, aiding in conveying bigger parts and larger volumes of material over long distances with ease. In addition, it’s designed for simple attachment to standard plumbing pipe couplers in order to take advantage of common pipes and fittings that are readily available.
Threaded Line Vac Conveyors utilize minimal amounts of compressed air to generate an instant and powerful vacuum on one end, with high output flows on the other. Regulation of the compressed air pressure also provides a fine-tuned control of the conveyance rate making it suitable for a wide range of applications including scrap trim removal, material conveying, part transfer, fiber tensioning and filling operations.
3 NPT 303SS Threaded Line Vacs are CE compliant and meet all OSHA pressure requirements. Ranging from 3/8 NPT through 3 NPT, all Threaded Line Vac models are also available in type 316 stainless steel to serve in exceptionally demanding corrosive, high temperature or hygienic environments. Visit EXAIR.com to explore the large variety of Air Operated Conveyors including Light Duty, Standard, Threaded, Heavy Duty and Sanitary Flange. 303SS Threaded Line Vac prices start at $327.00. For more information, visit exair.com.
Filed Under: Conveyors
