Longtime leading supplier of commercial and industrial grade lighting solutions Larson Electronics has announced the release of a 150 watt low bay LED light fixture that produces a 140° beam spread making it ideal for areas with shallow ceilings, producing a much wider light spread throughout an area.
The Larson Electronics EPL-HB-150LED-RT-140DB explosion proof low bay light fixture provides operators with a powerful and energy efficient alternative to traditional hazardous location luminaires. LED technology and a compact design make this lamp an excellent replacement upgrade option for older, bulky and high maintenance cost fixtures. This Class 1 Division 1 & 2, Class 2 Division 1 & 2 explosion proof LED light fixture provides 13,000 lumens of high quality light while drawing only 150 watts of power. The copper free aluminum alloy body is powder coated for added durability and aesthetics. A special heat dissipating design in conjunction with LED technology helps this fixture achieve an excellent 60,000 hour rated lifespan with 80% lumen retention.
This light is universal voltage capable and can be operated with 100-277 VAC, 50/60Hz without any modifications. This explosion proof LED light fixture is IP67 rated, dust-proof, and protected against high pressure jets and temporary submersion. The LED lamp produces 13,000 lumens with a color temperature of 6000K and a color rendering index of 70 which produces colors and details much more accurately than high pressure sodium or mercury vapor luminaires. The EPL-HB-150LED-RT-140DB low bay light fixture is supplied with a swivel mount bracket for surface mounting and can also be pendant mounted as well. Low bay light fixtures are recommended for mounting heights from eight feet to fifteen feet for best light distribution.
Larson Electronics will be attending the 2016 OTC show in Houston, Texas from May 2nd to May 5th. Visit them at booth 6716 to inquire about their lighting solutions for many industrial applications.
Larson Electronics
larsonelectronics.com
Filed Under: Lights • signal lamps • indicators, Flanges • supports • mounts • brackets, Power Electronic Tips
