MINNEAPOLIS, MN – Laser Design Inc. announced that it is now reselling Renishaw metrology probes and machine tooling, plus professional “Repair by Exchange,” and also used equipment. Renishaw products lead the industrial metrology market in accuracy and selection.
Offering the Renishaw multi-axis motorized and manual heads and touch-trigger measurement probe systems for CMMs adds another dimension to Laser Design’s extensive product line. The systems provide fast, accurate data acquisition for all your touch-measurement needs. Along with the systems, thousands of standard and custom Renishaw precision-engineered styli systems from a broad range of manufacturers are also available. Sensitivity modules allow custom probe settings.
To give you the best results with your system, styli specifically designed for high-precision Zeiss machines are easy to set up and change out. There are more than 300 styli and adaptors for the Zeiss range of probe heads. Robust design and construction characterize the styli specifically designed for the FaroArm portable CMMs. The special construction techniques ensure that the joint between the body and stem is extremely rigid and virtually indestructible.
Renishaw inspection probe systems can improve the efficiency of your machine tools by providing solutions for tool setting, broken tool detection, component set-up, and other essential inspection processes, while helping to reduce set-up times by up to 90%. Verify finished component dimensions and set up your auto updates to streamline the process. Specialized machine tool diagnostic software saves time and reduces scrap, which makes your operation more profitable and competitive.
Laser Design also offers “Repair by Exchange” (RBE) when a component needs professional repair or replacement. Or purchase high-quality certified used equipment through our used equipment sales program. If you need any kind of Renishaw product, we can provide it for you with our guaranteed excellent customer service and satisfaction.
Laser Design Inc. and GKS Global Services
www.laserdesign.com
Filed Under: Machine tool industry + subtractive manufacturing, Data acquisition + DAQ modules, Digital manufacturing, Lasers, Sensors (position + other), Test + measurement • test equipment
