ETEL will exhibit its full range of torque motors at this year’s IMTS 2014 show in Chicago’s McCormick Place (September 8-13). Offering four series of direct drive ironcore torque motors, ETEL boasts one of the most comprehensive ranges of such motors in the industry and will be exhibiting at Booth #N-6436 in McCormick’s North Hall.
Useful in many machine tool applications such as machining centers, milling/turning machines, rotary tables/milling heads, and multi-spindle and transfer machines, ETEL’s patented motor designs can be found in over 20 countries. Within ETEL’s TMK, TMB, TML and TMM series there are more than 100 models to choose from, allowing almost any relevant requirement to be successfully met.
All ETEL motors benefit from ETEL’s patented anti-cogging design along with a compact coil construction enabling an exceptional peak force density in the magnetic gap with minimum torque ripple.
Of the series, ETEL’s TMB torque motors are one of the most popular torque motors in its range, with a cage for water cooling. TMK motors are a unique type of very high speed torque motors for the most demanding applications. The TML and TMM are cageless variants of the famous TMB design. These variants are well suited when no water cooling is requested.
ETEL takes pride in their policy of full disclosure about their motor performances. It is standard for all data sheets to list its specifications at its highest operating temperature so that no special design is required to reach them, ensuring the user is able to utilize every bit of power that the motor is able to achieve.
ETEL
www.heidenhain.us
Filed Under: MOTION CONTROL, Motors (direct-drive) + frameless motors
