Orled announced the debut of their new line of high intensity ring lights, the Model RL16Q and Model RL28Q with Quadrant Driver. Designed to be mounted on a wide variety of microscopes and other optical systems, they are suitable for use in forensics, dental laboratories, medical and industrial manufacturing. The ring light with external control via serial interface is ideal for observing circuit boards, jewelry, and electronic and highly reflective specimens.
The light from high-output LEDS in 4 quadrants each with 8 step variable intensity from 0-100% is refracted through an innovative optical system to provide 85,000 lx at a working distance of 3 inches.
The 4 quadrant zones can be individually turned on and off allowing you to eliminate shadow for smooth, even illumination or create and control shadows to define surface details.
The RL16Q and RL28Q with Quadrant Driver comply with CE standards for European Community use.
ORLED
www.orled.com
Filed Under: Lights • signal lamps • indicators, ELECTRONICS • ELECTRICAL
