LEDtronics® announces their PAR36 Series Marker Lamps and Floodlights designed as an energy-saving substitute for PAR36 sealed beam lamps. These LED lamps create a bright and glowing spotlight that is perfect for many applications such as industrial vehicles, golf carts, architectural accent lighting, low-heat medical spotlighting, emergency egress lighting systems, landscape lighting, and other utilizations. The PAR36 Series lamp can be a direct drop-in replacement for 12/14Volt DC, 6Volt DC and 120Volt AC PAR36 incandescent lamps. The LEDtronics lamp housing is a sealed unit that protects the LEDs inside and is resistant to moisture and dust, making it perfect for outdoor purposes where it can withstand exposure to harsh environments.
The PAR36 LED lights are available in Warm White (3000 Kelvin), Pure White (5500 Kelvin), and Cool White (8000 Kelvin) color temperatures. For qualified customers, the bulbs are optionally available in other LED colors (including ultraviolet and infrared), voltages, and beam angles. The lamp generates a negligible amount of heat and can brightly indicate your presence while consuming only 4.5Watts of power. An LED cluster lamp continues to provide light even if one or more emitters fail–unlike when the filament fails in an incandescent bulb. PAR36 LED bulbs are designed to perform well in systems subjected to voltage dips or surges. Integrated current-limited resistors ensure that no circuit modifications are required.
Filed Under: Lights • signal lamps • indicators
