LED Machine Status Indicator Bulbs directly replace incandescents in critical instrument status indication applications. These bulbs are particularly good candidates for slot machine candles, casino gaming and maker lamps.
The W305SM series of omnidirectional miniature-based bulbs illuminate colored lenses with a much brighter light intensity, while remaining energy-efficient and tolerant of higher temperatures. This newest line of industry-leading LED bulbs features a T3¼ (9 mm) wedge base with bipolar terminals. The compact design of these indicator bulbs lets them easily install into tight spaces in enclosed fixtures. They can be directly installed, requiring
no modifications to the socket or to the circuit that supplies power.
Depending on the voltage and LED light color, power consumption ranges from only 0.6 to 1.8 W, offering luminous intensity from 25 to 85 lumens and efficacy values of 36 to 54 lumens/W. The series also has a maximum candela brightness value that ranges from 2,399 mcd to 8,661 mcd. They can be specified in virtually any combination of colors and operating voltages to fit the customer’s specific configuration and voltage requirements.
Featuring a 320°, no-shadow beam pattern, these omnidirectional LED bulbs provide higher-intensity illumination, better visibility, and uniform lighting compared to incandescent and halogens. They have lumen maintenance of over 70% at 15,000 hours. The solid-state, rugged polycarbonate design of the LEDtronics W305SM series bulbs renders them resistant to electrical/mechanical shock and vibration, frequent switching and environmental extremes. They have an operating temperature range of ~-40 to ~+212°F.
They come in a choice of four white color temperatures in 24-V ac/dc voltages: 1,800K Soft White, 3,000K Warm White, 4,000K Natural White, 5,000K Pure White; and 4,000K Natural White in 14-V and 28-V ac/dc voltages. They replace 24-V or 28-V ac/dc glass miniature wedge bulbs and color incandescent bulbs when used under a color-tinted lens.
Other voltages, colors and beam angles are available for qualified volume orders.
LEDtronics, 23105 Kashiwa Court, Torrance, CA 90505, (310) 534-1505/(800) 579-4875, Fax: (310) 534-1424, https://www.ledtronics.com/Products/product_select.aspx?id=W305SM-XIW-024V
You may also like:
Filed Under: TECHNOLOGIES + PRODUCTS, Lights • signal lamps • indicators
