Lenses for DMD projection by Sill Optics
By Zak Khan | July 21, 2015
s5lpj2620_rgb_1_190The use of DMDs (Digital Mirror Devices) in modern industry is becoming more and more important. Applications like direct exposure systems, 3D-measuring devices or even 3D-printers use DMDs for pattern generation.
To image this pattern onto a target requires special lenses, which take into account the fact that DMDs need illumination from the top with so called TIR prisms. These prisms have a glass thickness which must be included in the optical design of the lens. This block of glass requires an extra-long back focal distance of the lenses. In addition the imaging lens should be telecentric on the DMD side to guarantee the best homogeneity on the target.
All of these parameters are considered in Sill Optics’ projection lenses for DMD. They cover a magnification range from 0.5x to 20x with very low distortion values. Version for UV LEDs or for white light applications are available. Bi-telecentric lenses complete the spectrum of this product range.
Sill Optics
www.silloptics.de
Sensor Tips
Filed Under: Sensor Tips
Tagged With: stilloptics
Compact direct drive actuator boasts 1.25μm resolution
TMR magnetic sensors optimized for current, position sensing
Tiny dual-port pressure sensor simplifies design of PAP devices
AI/ML-based sensor fusion technology platform targets home-security alarm system
