Lenze Americas has launched the new 8400 HighLine Inverter Drives, part of the Lenze L-force 8400 portfolio. Designed for positioning applications, the HighLine model features integrated point-to-point positioning for up to 15 position destinations, and stores the corresponding travel profiles directly in the inverter.
The HighLine inverters’ integrated components translate to installation ease, with less cabling and a smaller panel size. Built-in advanced functionality includes linear and S-shaped travel profiles, a touch probe function, and homing selectable from 14 modes. The brake management system reduces wear on service brakes. A 2.5A digital output with integrated spark suppressor directly controls a 24V service brake. Standard features include an integrated brake chopper, switching logic for spring-applied brakes, a plug-in memory module, and CANopen communications on board with baud rate up to 1000kbit/s. Optional plug-in network communication modules are available for PROFIBUS, EtherCAT, PROFINET fieldbuses. HighLine can be supplied with a Safe Torque Off (STO) module that complies with IEC 61508, EN/IEC 62061, and SIL3.
Available in power ranges 0.25-15kW, HighLine delivers up to 200 percent rated torque. Performance pushes into levels that would previously have required servo technology, with HighLine positioning accuracies of 0.1-0.2mm at 60 operations (120 movements) per second. Lenze L-force Engineer configuration software offers users an intuitive, graphic interface that facilitates drive parameter setting and configuration. The High-Level Engineer version contains key functions for large scale projects, including establishing network, interconnecting communication and a function block editor.
Lenze’s 8400 HighLine inverter drives excel at controlled movement tasks at a considerably lower price point than servo technology. Industrial and manufacturing positioning applications might include cut-to-length machinery, rotary indexing tables, palletizers, extruders, hoists, filling systems, conveyors, turntables, gates and dosing pumps, and other motion control tasks. The L-force 8400 is a new range of inverter drives from Lenze. Four models with increasing functionality, the BaseLine, StateLine, HighLine and TopLine, optimize customer sizing, design flexibility, and cost savings. The Lenze 8400 Inverter Drives offer a fully compatible and consistently scaled range of modular drive solutions.
Lenze Americas
www.lenzeamericas.com
Filed Under: Factory automation, Automation components, Motion control • motor controls
