Lenze Americas (PACK EXPO Booth #S-5360) recently rolled out three new SMVector NEMA 1 models. The 40, 50 and 60 HP SMVector drives deliver superior performance and design flexibility in a broad range of AC motor applications.
SMVector drives provide robust features for demanding applications, including four modes of operation – V/Hz, Enhanced V/Hz, Vector Speed, and Torque – plus high starting torque, auto-tuning, advanced low-speed control, and dynamic speed regulation. Designed by Lenze as a universally applicable inverter, the SMVector has an input voltage ranging from 120VAC 1-phase to 600 VAC, 3-phase. The removable EPM (electronic programming module) memory chip allows customers to store operational memory and parameter settings for fast and efficient programming of multiple drives.
Accompanied by a major software upgrade, the new SMVector 40, 50 and 60 HP drives feature sequencer mode operation where up to 16 segments can be set, each at an individual frequency set-point, acceleration/deceleration time, digital output state, and analog input value. Advanced setup parameters include analog input configuration, deceleration override time, voltage midpoint and frequency midpoint V/Hz characteristics.
Plug-in communication modules make the SMVector easily integrated into commonly used industrial networks, including Modbus/RS485, DeviceNet, CANopen, PROFIBUS DP and EtherNet/IP, among others. Programmable digital and analog I/O allow SMVector drives to be configured for application-specific tasks, such as presetting multiple speeds, electronic braking, and motor jogging. The integrated dynamic brake connection requires only an external resistor for fast stopping or deceleration.
Lenze Americas
www.lenzeamericas.com
Filed Under: Factory automation, Automation components, Packaging, Drives (ac) + VFDs + starters, Motion control • motor controls, Motors • ac
