Leveling Mounts
By Design World Staff | September 27, 2007
J. W. Winco, Inc., offers an expanded line of inch size Threaded Stud Type “Level It” Leveling Mounts.
Made from carbon steel with a gold iridite plated or black oxide finish, the leveling mount has a stud ball end machined from solid bar. This leveling mount swivels 7 1/28 to all sides of the centerline to adjust to uneven surfaces and is used for leveling machine tools, electronic racks, benches, and more.  A jam nut is part of the “Level It‰” standard assembly. Modifications such as lag bolt holes and other versions of plating are available on request for certain minimum quantities.  In addition, the leveling mounts can be ordered with non-skid elastomer pads.  For non-skid applications, an elastomer cup pad version is also available.
www.jwwinco.com
Filed Under: Fastening + joining • locks • latches • pins, Mechanical
Tagged With: jwwinco
Covered compression latch enhances safety and reduces maintenance errors
Omron D41L hygienic guard locking switch is a tamper-proof solution for ensuring access control and workplace safety
Omron D41G guard lock and handle is an easy-to-wire and intuitive solution for safeguarding machine tools and robotic cells
Omron D41D high-coded non-contact door switch for safeguarding machine tools and robotic cells
