LF1E LUMIFA LED Light Strips from IDEC
By Patrick Curran | June 21, 2011
Looking for a cost-effective, low-maintenance lighting solution able to handle cold environments? LF1E LUMIFA LED Light Strips are specifically designed to be used in freezer or refrigerated display cases with ambient temperatures as low as -40 degrees C, while maintaining a long service life and providing consistent illumination levels. They are perfect for food displays, freezer units in grocery stores, deli counters and ice cream displays. In addition, they can be used in testing chambers where temperatures are below freezing.
Not only do these light strips perform well in cold tem¬peratures, providing uniform lighting for products while producing low levels of heat, they actually save energy since the refrigeration or freezer unit doesn’t have to compensate for heat generated by the light. Plus, operating on 24V DC voltage, these light strips retain 70% of their initial luminance at 40,000 hrs, making them a long-term, low-maintenance investment.
The LF1E series of light strips are available in Cool White (Temp: 5000K) or Warm White (3000K) and offered in four lengths with a maximum length of 1450mm (4.75 feet). Choose from three types: no lens, condensing lens and dual lens. All LF1E light strips are CE marked and UL listed for damp locations.
IDEC-LF1E-LED-lighting
IDEC Corporation
www.IDEC.com/usa/LUMIFA
Filed Under: Electronics • electrical, Lights • signal lamps • indicators
molex-premo-flex
