C&K has launched space-grade D-Subminiature surface mount termination (SMT) range of electrical connectors. The new SMT D-Sub connectors under CS-FR053 specification are primarily intended for aerospace engineering applications such as developing communication and network ports for satellites, spacecraft and launchers.
Reducing weight and making space savings on PCBs are critical requirements for connectors in space and military avionics applications, together with ensuring straightforward implementation and operational reliability. By utilizing SMT, C&K’s D-Sub connectors do not require plated holes to be drilled into the PCB, and free up one side for use by other components, resulting in a simpler, lighter design and a miniaturized footprint overall.
Constructed from a single part of machined aluminum shell, this latest series of connectors draws on C&K’s in-house technological expertise to achieve a smaller form factor than the traditional six-part copper-alloy stamped shell method. This means they can achieve up to 50% less weight compared to standard through-hole technology (THT) connectors. This construction technology also delivers better dimensional capability.
“With its combination of robustness, lightweight and small form factor, the SMT D-Sub connectors are in a class of their own in space and high-performance aerospace applications market,” said Rémi ANTOINE, Global Product Manager and Aerospace Segment Leader.
The D-Sub product lines conform to European Space Agency (ESA) standards and are qualified to the ESA/European Space Components Coordination (ESCC) code 3401. There are a large number of layouts available to serve most mounting configurations.
Filed Under: Connectors (electrical) • crimp technologies
