New relays are candidates for tough environments and incorporate a modular cover in IP00 and IP20 versions. The range of items covers 125 A and 200 Vdc or 660 Vac. Overvoltage protection (input and output) comes as standard. The relays can be mounted on panels or on DIN rails. Switching options include synchronous, asynchronous and special synchronous. The new range handles resistive, inductive and capacitive loads with a single product. It also includes diagnosis and load detection versions.
Crouzet’s static relays have been designed for most applications and have an extremely long lifespan. Easy to fit and easy to use, they are also sturdy and polyvalent. Ready for fitting thanks to a built-in self-adhesive thermal joint, the new GN+ Performance relays offer better immunity (rapid transients and shockwaves).
The other new addition, the GN Smart series, is particularly recommended for use with frequent load changes (e.g.: heat-hardenable molding) and can detect failures and damaged or disconnected relays. Applications include heating, movement, lighting components, and other industrial applications. All items are EC-certified with cЯUus. VDE is also available.
CROUZET, 12 rue Jean Jullien-Davin, CS60059 – 26000 Valence – France, +33 (0) 4 75 44 88 44, www.crouzet.com
You may also like:
Filed Under: TECHNOLOGIES + PRODUCTS, Relays
