LINAK introduces the latest addition to its product family, the LA23 electric linear actuator.
The LA23 has a compact design that allows it to be built into a variety of applications, especially where space is a concern. The width is only 1.7 inches (43mm) with height of 3.35 inches (85mm) and the housing measuring 4.84 inches (123mm) – compact enough for even the smallest application.
Being small does not compromise the strength of the LA23. This actuator is capable of over 560lbs (2,500N) of force in push or pull.
The LA23 was designed to be used in markets where space is a concern. It is ideal for wheelchairs and patient lifts in the medical market. In addition, the LA23 is ideal in industrial markets for applications such as industrial vents. The possibilities are endless.
An additional key feature of the LA23 is exchangeable cables. This allows for optimized logistics and easy cable replacement.
LINAK
www.linak.com
Filed Under: Actuators, Factory automation, Linear motion • slides, Motion control • motor controls
