    • On the Floor
LINAK introduces compact LA21 actuator for OEM applications
By Puja Mitra | November 18, 2025
LINAK’s new LA21 electric actuator targets OEM demands for compact design, precise motion and reliable performance in challenging conditions.
Faster cycles and consistent results
The LA21 is the fastest actuator in its size class, combining high speed with low backlash and a high position resolution for precise, repeatable motion. This supports shorter cycle times, stable output and consistent product quality without extra adjustments.
Compact design that fits constrained spaces
The LA21 is built to fit into limited installation areas. Its compact footprint integrates easily into tight systems, giving machine builders more flexibility without having to work around larger components. Despite its size, it provides steady, reliable performance, making electric actuation possible in applications that previously lacked the necessary space.
Reliability suited for demanding environments
The LA21 is built to operate in conditions that include vibration, moisture, chemical exposure and a wide range of temperatures. Its metal gears, established housing design and integrated brake contribute to stable, long-term performance similar to larger actuators. For OEMs, this can help reduce unplanned downtime and limit maintenance needs.
Why OEMs choose the LA21:
  • A competitive advantage in machine speed and accuracy
  • Easier integration in compact, efficient designs, which saves time
  • Long-term reliability in tough industrial and outdoor environments
For more information, visit linak-us.com.
Tagged With: linak
Puja Mitra
  • Robot blowback in Korea and China growth slows
  • Robot safety in focus as regulations change
    • On the Floor
