Waterbury,CT – Haydon Switch & Instrument, Inc. is proud to announce that its size 14 hybrid linear actuators are now available with an integrated connector.
Offered alone or with a harness assembly, this connector is RoHS compliant and features a positive latch in order for high connection integrity. The connector is rated up to 3 amps and the mating connector will handle a range of wire gauges from 22 to 28. This motor is ideal for those that want to plug in directly to pre existing harnesses. Available in three designs, captive, non-captive, and external linear, these size 14 hybrid linear actuators are available in a wide variety of resolutions ranging from 0.00012″ (.003048 mm) per step to 0.00192″ (.048768 mm) per step and deliver thrusts of up to 50 lbs. without compromising long life and cost. These hybrid linear actuators can be micro stepped for even finer resolutions.
Applications requiring precise positioning and rapid motion are best suited for this motor. Priced competitively, this product is ideal for drop-in replacements to improve performance and life or for incorporation into your next project. In addition to standard configurations, Haydon can custom design this motor to meet your specific application requirements.
Filed Under: Actuators, Motion control • motor controls
