Linear Ball Bushings
By Design World Staff | May 25, 2007
MISUMI offers an extensive line of linear ball bushings for most factory automation applications. Bearings come in varying shape, length, material, and surface finish combinations. Choose from either 52100 bearing steel or 440C stainless steel. Electroless Nickel Plating is offered as an optional surface treatment for 52100 bearing steel. Furthermore, compatible spacers, stopper plates, and mounting housings are also available.
Bearings can be ordered using MISUMI’s Web Ordering System. Customers can get instant price and shipping information and can also obtain a request for quotation (RFQ). The Web Ordering System provides historical order and quotation information, which allows the customer to maximize the use of common components across multiple machines. Also, RoHS compliance and other data are available at the component level for most components.
For more information, please contact:
Dwayne J. Roark
Senior Marketing Manager
MISUMI USA, Inc.
1105 Remington Road
Schaumburg. IL 60173
Tel: (800) 681-7475
Web: www.misumiusa.com
About MISUMI USA, Inc.
Located in Schaumburg, Illinois, MISUMI USA, Inc. was established in 1988 as a subsidiary of Japan based MISUMI Corporation. MISUMI USA, Inc. is a leading supplier of configurable and fixed components for factory automation. In addition, MISUMI USA, Inc. offers a range of press and plastic die components, cutting tools, and gauges.
:: Design World ::
Filed Under: Factory automation, Bushings • plain (sleeve) bearings
