Freeport NY – New low-profile linear shaft supports from Ondrives Corp. feature a unique removable top. Using top loading makes for easier assembly and accurate re-alignment of shafts and bearings when needed with less downtime. The removable top allows quick replacement without the loss of alignment position.
These patent-pending LPB shaft supports are also low profile, only 0.87-in. high for a 0.25-in. shaft diameter. For shaft diameters from 0.25 to 2.0 in., there are 9 different sizes available. Metric bores are also available. The LPB shaft supports are also RoHS compliant and are precision manufactured in aluminum, are gray anodized, and have alloy steel fasteners.
