FUTEK LCM100 in-line load cell is an ultra-miniature threaded design that has a capacity range of 1000g to 25 lb. Utilizing metal foil strain gauge technology, the sensor can be used in both tension and compression applications. The design’s very low deflection allows it to provide high response rates and superior settling times.
The sensor has a rated output (R.O.) of 1 mV/V (1000 g, 5 lb) and 2 mV/V (10 lb, 25 lb). With nonlinearity ±0.5% of R.O., hysteresis of ±0.5% of R.O. and nonrepeatability of ±0.1% of R.O., the sensors can address many stringent requirements.
The RoHS-compliant housing uses 17-4 PH stainless steel construction and has a minimal mounting clearance.
For more information, click here.
Filed Under: Sensor Tips
