Locking collar keeps bearing secure
By Kathleen Zipp | June 27, 2007
Marathon Composite Mounted Bearing Units added a locking collar that increases the contact area between the bearing and the shaft, ensuring a strong, secure, slip-resistant fit. The new units are suited for applications that have constant direction of rotation or experience frequent starts and stops, including machinery used in the vegetable, fruit, and food processing industries, and industrial operations. They also make bearing removal easy because the set screw dimple created on the shaft during the initial mounting procedure is more accessible. The raised edges around the dimple can then be filed to easily slide the bearing off the shaft.
MRC Bearing Services, div of SKF USA Inc.
www.mrcbearingservices.com
:: Design World ::
Filed Under: Bearings, Packaging
Spacecraft, Vacuum Condition
Bearing life and effects of harsh operational environments
Figure4
How to make a gear-bearing from advanced polymer components
igus presents solutions to support mobility trends
bearing covers
Stock polymer and steel wheel covers for radial ball bearings
