Long Distance Industrial Wireless Transmitters And Receivers
By Design World Staff | October 26, 2010
Omega’s new industrial wireless transmitters offer unparalleled flexibility for process measurement applications. These transmitters are designed for a variety of applications, including temperature, infrared temperature, relative humidity, process transducers with standard voltage or current outputs, flow (pulsed frequency) as well as pH.
omega-Wireless-Transmitters-And-Receivers
Thermocouple, RTD, Infrared Temperature, RH, Ph, Process Voltage/Current and Flow/Pulsed Frequency Input Models are available. The UWXL has a IP68 Rated Industrial Enclosure, includes free software that converts your PC into a multi-channel chart recorder or data logger and is compatible with both of Omega’s UWTC-REC and UWXL-REC wireless receivers.
Omega Engineering
www.omega.com
Filed Under: Wireless, Sensors (position + other), Test + measurement • test equipment, Wireless devices
mti
MTI
moog
