Low-Cost Control Cabinet PC Equipped With Swappable RTC Battery
By Advantech | April 24, 2018
Advantech’s IIoT Automation Group is pleased to announce the UNO-1372, a low-cost control cabinet PC powered by Intel® Celeron® J1900 quad-core processor with four GB DDR3L memory, dual display interfaces (HDMI and DisplayPort), two GbE LAN, two mPCIe/mSATA, four COM, four USB, and eight digital I/O for convenient connectivity and data transfers.
The aluminum housing with chassis grounding protection prevents damage from electrical surges and enhances heat dissipation while the system’s rugged fanless design, wide operating temperature range
(-20 ~ 60°C) and shock and vibration tolerance (IEC 60068-2-27/IEC 60068-2-64) provide the durability to withstand operation in harsh environments.  To facilitate flexible configuration and easy expansion, the UNO-1372G supports Advantech’s iDoor technology.  This allows the system to be integrated with diverse expansion modules for Fieldbus protocol support (Profibus, Profinet, EtherCat, and Powerlink), additional memory/storage, digital and analog I/O, smart sensors, and wireless communication (3G, GPS, GPRS, Wi-Fi, RFID, Bluetooth, and LTE).
The UNO-1372G is equipped with a swappable RTC battery that can be replaced in the event of failure without disruption to the mainboard clock and built-in Trusted Platform Module (TPM) 2.0 chips that provide hardware-based security to ensure secure data transfers.
With support for multiple drivers for OS, including Windows 7, Windows 10, and Embedded Linux, the UNO-1372G provides a versatile application-ready platform for smart factory applications.
Advantech’s UNO-1372G is available for order now.
