Most industrial clutches and brakes are measured in the millions of cycles, but when you have applications such as high volume mail sorting machines life needs to be measured in the tens of millions of cycles. To accomplish this high cycle life, Ogura uses ceramic friction material as an option in the AMC series of clutches and brakes. In most high cycle applications, Servo systems are used instead of clutches and brakes. Normally, they are the only solution to achieve both high cycle rates and fast response time.
Ogura’s modified AMC clutches and brakes allow customers an alternative to Servos. Although response time varies based on inertia, typical response times are around 25 milliseconds. This is the actual time to speed/time to stop, not a response time of the clutch or brake (which is faster at around 10 milliseconds). To accomplish quick response times, Ogura uses spring loaded, zero gap armatures. Typical cycles for the clutch and brake on machines are in the 30-50 million range. For customers that are looking to reduce their machine cost and still maintain long life, Ogura ceramic faced clutches and brakes are the answer.
Ogura Industrial Corp.
www.ogura-clutch.com
Filed Under: Brakes • clutches, Drives (servo) + amplifiers, Mechanical, Motion control • motor controls
