Omega’s new AHPF series heaters are used to heat low flows of air, gas, water, or aqueous solutions with air/gas flow up to 15 CFM and air/gas out temperature up to 430°C (800° F). This 316 Stainless Steel constructed heater can handle pressures up to 100 PSI and 50 watts per square inch. Applications include those where clean air is necessary, as in laboratories, environmental testing areas, packaging and sealing. Ideal for the automotive, petroleum and manufacturing industries.
Omega Engineering
www.omega.com
Filed Under: Automotive, AUTOMATION, ELECTRONICS • ELECTRICAL
