New clock IC enables the unique functionality of the JESD204B SERDES high-speed interface
Norwood, MA (12/02/2014) – AD9528 provides a low-power, multi-output, clock distribution function with low-jitter performance, along with an on-chip, two-stage PLL and VCO. The on-chip VCO tunes from 3.6 GHz to 4.0 GHz, with the input receivers and oscillator providing both single-ended and differential operation.
The AD9528 provides JESD204B-compatible subclass 1 SYSREF and deterministic latency clocking signals and supports a variety of options for SYSREF signal generation. The most basic is a simple buffer function wherein the user-provided SYSREF signal is fanned out to the SYSREF output pins. When provided with an external SYSREF source, the AD9528 is also capable of synchronizing the SYSREF outputs to the clock outputs being generated internally, which is necessary to achieve accurate deterministic latency. The AD9528 is also capable of generating the SYSREF source internally. The AD9528 supports both continuous signal SYSREF generation and “n-shot” pulse generation. N-shot generation is vital in systems where a continuous signal might result in unwanted spurs in the output spectrum of the data converter being clocked.
When connected to a recovered system reference clock and a VCXO, the AD9528 generates 12 low-noise outputs with a range of 1 MHz to 400 MHz, and two high-speed outputs at up to 1.25 GHz. The frequency and phase of one clock output relative to another clock output can be varied by means of a divider phase-select function that serves as a jitter-free, coarse timing adjustment in increments that are equal to half the period of the signal coming from the VCO output. The SYSREF signals each have additional phase offset capability making it easy to dial-in the optimal arrival time at each target device.
The AD9528 can be designed into wideband RF data acquisition applications with ADI’s AD9680 dual-channel, 14-bit, 1.0-GSPS JESD204B A/D converter.
The post Low-jitter 1.25-GSPS clock optimizes JESD204B serial interface functionality in GSPS data converter applications appeared first on Analog IC Tips.
