Low leakage current 3-phase filter, FMBC LL
By Frank Tobe | October 24, 2014
SCHURTERSCHURTER expands its successful range of FMBC NEO 3-phase filters with a low leakage current series for applications where leakage currents are restricted to minimal allowable levels. The new FMBC LL family of filters is designed for rated currents between 7 and 180 A. The new series is ideal for applications such as drive technology, where such leakage current restrictions are critical.
Today’s electrical industrial installations are increasingly being fitted with residual current devices (RCD) to ensure human safety. This is also a requirement in certain countries for 3-phase systems, for example plug-in systems up to 32 A. The RCD limits the current to ground to a maximum of 30 mA. This limitation on the RCD poses a particular problem in drive technology since the frequency inverters that control the engine generate considerable leakage current. Long motor cables further aggravate the problem, since they increase the capacity to ground and thus the currents to ground. The new series of FMBC LL filters helps reduce leakage currents and permits compliance with common EMC standards as an efficient input filter.
The compact FMBC LL 3-phase filters have been designed for currents from 7 A to 180 A at 520 VAC and an ambient temperature of 50 °C; +40 °C at a higher rated current. The leakage current rating for versions 7 – 55A is < 5 mA and
The standard FMBC LL is fitted with a screw connection. Other types of connections including wires or copper bars are available on request. Custom options to the circuitry are also possible, as well as variations in housing styles. SCHURTER also offers its own EMC measuring service for optimizing the most efficient filter solution for the best system performance.
SCHURTER
www.schurter.com
Filed Under: MOTION CONTROL
Tagged With: Schurter
