VarioFlow plus is a flexible chain conveyor system easily configurable as individual, space-saving systems for versatile, complex transportation tasks, even for particularly difficult environments.
The conveyor system offers a number of standard modules covering differing application requirements with maximum interchangeability and modularity. The MTpro planning software with Layout Designer helps simplify selection and combination of the modules. You can design conveyors and complex multi-conveyor and workstation systems, select components and output the results to CAD.
With the drive, you can choose the motor mounting position on-site, reducing the selection of drive variants. The conveyor is quiet, thanks to optimized conveyor sliding characteristics and use slide rails with lateral mounting, ensuring less wear and fast, reliable assembly.
Components can be used universally for all system widths, including the new track width of 120 mm, reducing the need for spare parts. Additionally, the stable chain permits tensile forces up to 1,250 N. The chain surface is nearly closed, allowing even the smallest parts to be transported safely and reliably.
The system offers individual conveyor layouts and comes in six sizes. It has two material options: a basic aluminum version and a stainless steel version for applications with higher hygiene demands.
Bosch Rexroth
www.boschrexroth-us.com
Filed Under: TECHNOLOGIES + PRODUCTS, Conveyors
