PI’s ultra-low profile (14 mm / 0.6”) linear-motor driven M-692 series of translation stages was designed for high-speed, high-stability positioning tasks with limited space. These stages are the lowest profile closed-loop linear motor equipped micropositioning systems in the industry. Based on PI’s proprietary PILine® ultrasonic ceramic motor technology (US Pat. No. 6,765,335) these stages provide velocity to 350 mm/sec, while holding a stable position with zero energy consumption when at rest.
Two standard versions are available: M-692.1U4 with 20 mm stroke and M-692.2U4 providing 90 mm. Both versions are equipped with integrated linear encoders for backlash free positioning. The stages can be arranged to form compact XY systems. The basic design is scalable and can be varied to provide different travel ranges to 300 mm. Vacuum-compatible versions are also available on request.
For optimum performance the highly specialized C-867 motion controller is recommended. This dedicated piezo motor controller also integrates the drive electronics which PILine® motors require to generate the ultrasonic oscillations for the piezoceramic element. Furthermore, the controller has a number of special characteristics, including continuous automatic drive frequency adjustment, dynamic parameter switching for optimized high-speed motion and settling behavior and some other features to address the requirements of ultrasonic motors.
PI (Physik Instrumente)
www.physikinstrumente.com
Filed Under: Encoders • linear, Linear motion • slides, Motion control • motor controls, Motors (linear), Stages • gantries
