  • Articles
  • 3D CAD Models
    • 2020 Winners
    • 2019 Winners
    • 2020 LEAP Awards
    • DIGITAL ISSUES
      • EE World Digital Issues
    • 2020 LEAP Awards
    • Motion Design Guide Library
    • Suppliers
  • COVID-19
Low-smoke, zero Halogen ribbon cables
By Mary Gannon | December 1, 2020
Cicoil now offers Low Smoke Zero Halogen (LSZH) IDC Ribbon Cables for applications that require non-toxic, corrosive free, low smoke, flame retardant, zero halogen content and environmentally friendly cables. Unlike other LSZH cables that tend to be stiff, Cicoil’s ultra-flex design is the perfect alternative.
Cicoil LSZH IDC Ribbon CableThe Ultra-flexible IDC Ribbon Cable is jacketed with Cicoil’s proprietary Flexx-Sil rubber jacketing material and has been tested by a UKAS certified lab for smoke, toxicity, flammability and halogen content. The Cable passed all tests.
Typically, electrical cables manufactured with Fluoropolymers, PVC and Neoprene require the addition of halogens to make them flame retardant and to withstand high temperatures. However, when cables infused with halogens are burned, toxic fumes and acidic gases (when bonded with hydrogen) are produced, which sear the eyes, nose, mouth and throat and cause severe respiratory damage, disorientation and even death.
Fortunately, Cicoil’s proprietary Flexx-Sil jacketing material utilized on its IDC cable contains zero halogens, no additives and by nature are flame retardant (HFFR), so they are the safer alternative to those cables manufactured with harmful ingredients. Due to its unique mixture of materials, the ultra-pure Flexx-Sil does not ignite easily, and if ignited, will not produce black smoke or toxic gas during combustion. In addition, Cicoil’s “Crystal-Clear,” non-corrosive jacket does not contain color additives, plasticizers or CFC’s, which are typically found in most cable jacketing materials.
Cicoil’s 28 AWG IDC Ribbon cable is designed to work directly with standard Insulation Displacement Connectors (IDC). The wire spacing and dimensions are standardized, with the wire ‘pitch’ (wire spacing) set at 0.050 in. for the English version, or 1 mm for the metric version. Cicoil’s ribbon cables are available with up to 64 conductors, meet the standard ribbon cable dimensions and are completely compatible with any IDC connector.
The ultra-pure Flexx-Sil jacket offers 100% transparency, is self-healing from small punctures and will not deform or prematurely age due to prolonged exposure to sunlight, steam, Arctic temperatures (-65°C), high heat, (260°C) ozone, UV light, radiation, humidity, fungus, acid, water, sodium chloride, vibration and many chemicals. When a non-adhering or abrasion resistant jacket surface is desired, Cicoil offers its SlideRite and GlideRite coating options by request.
Cicoil’s halogen-free, low smoke and flame resistant IDC Ribbon Cables are UL Recognized, CE Conforming, RoHS & REACH Compliant, Class One Clean Room Rated and are cured continuously, with no debris or material contamination in an automated, climate controlled environment. In addition, the cable jacket passes UL/CSA VW-1, FT 1 & FT 2, UL 94V-0 flammability testing, FAA burn testing, exceeds the outgassing requirements of ASTM E595, and are excellent for use in vacuum environments.
Cicoil
www.cicoil.com
MOTION DESIGN GUIDES
  • Configuration Management: Configuration Integrity IS A Core Driver for Business Success
  • How to Choose a Linear Actuator
  • Create your perfect machine with Advanced Engineering
  • How a ME/EE turned passion for design into his own bike company
  • Everyone Can Save on Cable Costs. Here’s How
  • How and Why You Should Use a Wave Spring for Bearing Preload
Tweets by @DesignWorld
  • Articles
  • 3D CAD Models
    • 2020 Winners
    • 2019 Winners
    • 2020 LEAP Awards
    • DIGITAL ISSUES
    • 2020 LEAP Awards
    • Suppliers
  • COVID-19
