LPI Series Illuminated Pushbutton Switches
By Design World Staff | December 18, 2008
Haverhill, MA – APEM Components, Inc. announces the release of its LPI series illuminated pushbutton switches. The LPI, with its large actuator surface and light actuation force is designed to be compliant to the Americans with Disabilities Act (ADA). This product is well-suited for various indoor applications where the push-button needs to be located quickly. Typical applications include door access controls and personnel lifts. This product is also ideal for applications where the end-user wears gloves.
The LPI has been developed on a modular basis, configurable to fit the exact needs of end-users, with over 20,000 possible configurations. The LPI is offered with 9 different bezel colors, 5 LED colors and illumination in a dot or light-ring configuration. The LEDs are available in 6, 12 and 15 volts. Actuator can be produced with raised crimps, screen printed emblems or raised molded symbols.
The LPI pushbutton switch has two electrical ratings; 50 mA at 12 VDC and 5A at 12VDC. The switch is provided with either gold or silver contacts and the low current version is rated at up to 5 million cycles. Electrical functions include single and double throw in NO and NO/NC configurations.
With its 35mm diameter actuator and an actuation force of less than 1 lb this series is ideal for ADA compliant door access applications. Complying with the requirements of both the EN81-70 standard (from Disability Discrimination Act) and the ADA, the LPI switch allows disabled persons to more easily access buildings and lifts.
www.apem.com
Filed Under: Electronics • electrical, Switches
molex-premo-flex
