(Lexington, KY )— The new LS04 pneumatic valve series from Rexroth has dimensions of only ten millimeters width and a flow rate of 200 l/min (0.2Cv) up to a maximum of 330 l/min (0.33Cv).
The LS04 series comes in three different designs: a mini valve with optimized dimensions and a flow rate of 200 l/min (0.2Cv), a standard valve with 250 l/min (0.25Cv) and a valve manifold system with a flow rate of 330 l/min (0.33Cv). All valve variants are made of high strength polymer.
The LS04 features integrated push-in fittings for inch or metric tubing (working ports range from 1/8” to 1/4” and 4mm to 6mm). The electrical connections for the three types varies: the inline single valves are equipped with an M8 connector or standard connector and the valve terminal system has a multi-pin connection that can be used to control up to 24 coils. Users can implement mixed configurations with single and double solenoid or double 3/2-way valves.
Additionally, users can create different pressure zones or supply circuits in the valve terminal system using separators that can be positioned anywhere, making it possible to flexibly adapt the configuration to individual demands. The plug-in style valves can be exchanged without interfering with the electrical connections and the system can be expanded at a later point with two more valve positions.
The compact mini valve in the LS04 series covers the entire needs of modern valve technology for flows of up to 200 l/min (0.2Cv). As a 5/2-way valve, it takes care of the most common valve functions and can be operated with lubricated or non-lubricated compressed air. This also applies to the standard valve, particularly with the double 3/2 (split spool) function. Users in handling technology can also directly mount the LS04 on moving parts, thanks to its low weight. Even vacuum applications can be implemented with this valve, as it uses an external pilot air supply.
:: Design World ::
Filed Under: Pneumatic equipment + components, Valves
