    • Subscribe!
LS05 Liquid Level Sensors from MEDER electronic
By Patrick Curran | January 25, 2010
MEDER electronic, Inc. releases their new LS05 Liquid Level Sensors, made of tough stainless steel tubing, these sensors can be customized up to 6.5 feet in length, detect multiple liquid levels and withstand exposure to many chemical solutions, high pressure and high temperatures.
meder-LS05-liquid-level-sensor
The LS05 Series Liquid Level Sensors is the most diverse level sensor yet, combining hundreds of standard options ranging from switching power and connectivity to fluid types and number of liquid levels. The LS05 housing stem, constructed of V2A stainless steel can vary in length up to 6.5 feet long and hold any number of magnetic floats with a minimum spacing of 1.5” between them. Its stainless steel housing will withstand high pressure up to 12bar and temperatures up to 200°C when coupled with stainless steel floats. Choose from 10 different magnetic floats, available in four different materials: Polyamide (PA), Polypropylene (PP), Nitrile Butadiene Rubber (NBR) and Stainless Steel (V2A).
Mix and match more than one float material to detect multiple fluid types in the same tank, such as in a diesel tank that may build up water condensation over time. The LS05 can be mounted to the top or bottom of a tank or reservoir using a number of different mounting options. Using our OKI and KSK Reed Switches, the LS05 can switch low and high voltages up to 1000 Volts and produce single, multiple or continuous output signals. The LS05’s multitude of standard options simplify the process of designing a liquid level sensor for such a diverse array of liquid detection applications.
MEDER electronic Inc.
www.meder.com
Filed Under: Sensors (position + other), Test + measurement • test equipment
mti
MTI
moog
    • Subscribe!
