LUMICLAD® Process From Birchwood Casey
By Laura Carrabine | October 20, 2010
Design engineers requiring break-in lubricity and galling resistance for mating aluminum surfaces have a new option with the LUMICLAD® finish.
BirchwoodCasey-Lumiclad
The LUMICLAD process forms a non-dimensional black oxide finish on all aluminum surfaces that is clean, durable and tightly adherent to metal substrate. The finish has an inherent lubricity that aids in break-in and resists galling, making it an ideal finishing choice for product assemblies with sliding contacts. Aluminum machine components, such as piston/cylinder assemblies, actuator mechanisms, slides and valve assemblies achieve smoother break-in with a LUMICLAD finish than with conventional anodized finishes.
Proven in real-world applications, the LUMICLAD finish offers superior conductivity and break-in lubricity in an attractive and protective black finish that is simple and economical to apply. The 30-minute process develops a uniform coating thickness of .000060 inches (1.5 micron) that will not close down hole diameters or change critical part dimensions. The black finish is smooth, clean and electrically conductive, making it the coating of choice for assemblies requiring a chassis ground.
The unique, patent-pending LUMICLAD process delivers a smooth satin black finish with a slightly porous crystal structure that absorbs an optional topcoat, such as clear polymer, light oil or dry-to-touch sealant.
Prior to the development of this new blackening process, black anodizing had been the only viable blackening option for manufacturers of aluminum components. While the anodized finish is extremely durable, the process is so complex that only those who specialize in it can operate it properly and consistently. Though the protective properties of a black anodized finish are high, often they are higher than the application requires and they come at significant additional cost.
By contrast, the LUMICLAD process utilizes a conventional immersion tank process line. It is easy and safe to operate so that manufacturers can operate it in-house themselves, thereby eliminating the need for outside processing. For most applications, a seven-tank line and a 30-minute process time does the job from start to finish
Birchwood Casey
www.birchwoodcasey.com
Tagged With: birchwoodcasey
EXE014 - Image 1
