    • On the Floor
LUMIFA LED Light Strips from IDEC
By Dave Miyares | June 16, 2009
Sunnyvale, CA—New LED light strips from IDEC are the brightest in their class at up to 67.2 Lumens/Watt. Reinforced glass models bring to the table an impressive IP67f degree of protection against water, dust and oil making them perfect for machine tools or outdoor equipment. A polycarbonate plastic cover with IP67 degree of protection is also available, ideal for food processing applications.
Plus the LF1D Series retains 70% of its initial luminance at 50,000 hrs. These light strips are Cool White (Temp: 5700K) and offered in a slim (10 x 1 LED array) or wide type (7 x 2 LED array) with 24V DC voltage. Manufactured with a sturdy die-cast aluminum housing and stainless steel front cover, they are also RoHS compliant, mercury-free. UL approval is pending.
Two cable options are available: side connection and back. Plus removable direct plug-in terminal block and spring clamp connections ensure a high-quality connection, making it easy to install or replace the LED illumination unit.
IDEC
www.idec.com/usa/
Filed Under: Lights • signal lamps • indicators, ELECTRONICS • ELECTRICAL
    • On the Floor
