Sunnyvale, CA ‚– IDEC continues to move towards a green future and announces the LUMIFA series of LED light strips, LF1A and LF1B. With a minimum lifespan of 40,000 hours and only using one-third the energy of fluorescent lights, LUMIFA LED light strips are the smart way to save time and energy.
These environmentally-friendly light units are perfect for areas where repairs can not be easily performed. Once installed, these light strips can be left on for years without needing maintenance or replacement, saving you valuable time and money! Plus these LED light strips provide a very bright light source while producing little heat (even less than a fluorescent lamp). LF1A and LF1B light strips have a rated voltage of 24V DC.
LF1A LED strips use super-bright multi-chip LEDs providing illumination equivalent to a 20W fluorescent lamp, while consuming only one third the power. They come in a thin housing available in three sizes with four color configurations (warm white, cool white, yellow and red).
An internal waterproof gasket and transparent panel with thick reinforced glass make LF1AD2F LED light strips perfect for use in a food processing line or outdoors where they might be immersed or sprayed with water or oil. These light strips are IP67f rated and also RoHS compliant, mercury free.
LF1B miniature LED light strips are housed in a thin light strip, and are available in four sizes with a choice of two covers (transparent or white). These LEDs can provide protection from dust, as well as from limited water spray and are white in color.
Filed Under: Lights • signal lamps • indicators, Green engineering • renewable energy • sustainability
