Overload current-control module features super-thin form factor
By Lee Teschler | November 22, 2021
An upgrade of the LOCC-Box module allows completely tool-free installation in the control cabinet. Instead of the cage clamps that are usually used, LÜTZE uses the future-oriented Push-In technology and therefore offers a much greater clamp gauge. Conductor gauges up to 2.5 mm² with and without ferrules are possible and can be connected easily. Ergonomically arranged blue actuators allow easy dismantling of the conductors. The new modules have a test opening; the proven slit for the bridging system continues to ensure less wiring effort.
The new LÜTZE LOCC-Box Module handles current control up to DC 10 A for Industry 4.0 tasks. The LOCC-Box housing is now 8 mm thinner creating even more space and free flowing air in the control cabinet. A lutzespring integrated into the base of the module improves the hold significantly; the LOCC Box therefore sits securely on the DIN hat profile. The new, rounded design of the LOCC-Box aids innovation and handling efficiency, and installation is now smoother and easier. Also, the LÜTZE engineers have equipped the LOCC-Box with additional LED functions that inform the user about the actual and target settings.
The new LOCC-Box modules are compatible with all previous models and will be available from the first quarter of 2022
The LOCC-Box (LÜTZE Overload Current Control) has now become a quasi standard in many control cabinets with regard to overload and short-circuit control. Thanks to the patented trigger behavior along defined characteristic curves, the LOCC-Box allows the creation of selective voltage supplies. In the event of an error, only the affected circuits are shut down, and the other unaffected circuits can continue to function. The system stores errors and thereby prevents the reoccurrence of the same malfunction the next time it is switched on. Errors are reported to various field bus systems either by means of hardware or via a gateway. LÜTZE supplies the LOCC-Box in various models: The standard models–LOCC-Box-FB and LOCC-Box-Net–offer up to 50 setting options. LOCC-Box-Net is designed for communication via various field buses and is therefore a candidate for Industry 4.0 or IIoT applications.
LUTZE Inc., 13330 South Ridge Drive, Charlotte, NC 28273, +1 704 504-0222, Fax: +1 704 504-0223, www.lutze.com
You may also like:
  • PCB mills
  • Did you foresee Facebook?
  • 9-11 truthers
    The WTC collapse after two decades
  • scilab
    The top ten free engineering math software packages
  • don't worry about EV fires
    Don’t worry about EV fires
Filed Under: TECHNOLOGIES + PRODUCTS, I/O modules
Tagged With: lutze
PROSTEP expands cooperation with Siemens Digital Industries Software
DRP - Line
Andantex will introduce a new planetary reducer design concept at IMTS
Custom pneumatic conveyors for unique applications
Advantech-iDAQ-3
Advantech launches iDAQ modular DAQ
