AutomationDirect has added new LUTZE RJ45 shielded IDC field wireable connectors and adapters to their Wiring Solutions lineup. RJ45 IDC shielded field wireable connectors with 8-pole configuration provide quick and easy Cat6a connections to non-terminated cables allowing custom-built connections to fit your application. The RJ45-to-RJ45 8-pole bulkhead adapters can be installed in a control panel cutout allowing easy pass-through for Cat5e or Cat6a connections and include a protective cap to protect the outer connector when not in use.
New DIN rail-mounted holder modules for RJ45 Cat6a shielded IDC field wireable connectors provide connectivity between the field and the control panel. These holder modules simplify the wiring process in just a few simple steps and do not require any tools. The modules’ side covers can be removed, allowing several modules to be installed side by side on a DIN rail, which is ideal for tight-spaced installations.
AutomationDirect
www.automationdirect.com/cable-connectors
Filed Under: Connectors (electrical) • crimp technologies, Connector Tips
