Alliance Sensors Group a div of H.G. Schaevitz LLC linear position product line of LVITs (Linear Variable Inductive Transducer) is a true disruption in the industrial position sensor industry by merging the benefits of contactless inductive sensing and low cost of contact based technologies. ASG’s line of LVITs has been expanded yet again to now include a spring-loaded version. LVITs are contactless devices designed for factory automation and a variety of heavy-duty industrial or commercial applications such as solar cell positioners, wind turbine prop pitch and brakes, chute or gate positioners on off-road or agri-vehicles, bridge expansion and rail sun kink monitoring, robotic arm position feedback, snow plow positioning, automotive/motorsports, and packaging equipment. With their compact yet robust design, superior performance, and excellent stroke-to-length ratio, ASG’s LVITs are ideal for both industrial and OEM position sensing applications.
All LVITs Have the Following Features:
- The NEW LZ-25 can be mounted on hydraulic cylinders
- Contactless operation prevents wear out from dither or cycling
- Ranges from 12.5 to 450 mm (1/2 to 18 inches)
- Radial cable exit version comes with swivel rod eye ends
- Four Analog outputs
- Axial termination versions with either M-12 connector or 1m cable
- ASG’s proprietary SenSet™ field scalability
THE NEW LRL-27 is a continuation of the LR-27 for longer range applications (10-18”)
THE NEW LZ-25- Through bore LVIT that can be mounted on Hydraulic Cylinders
The LZ-25 is a through bore design with ranges from 2-36” and EXTREMELY GOOD Stroke-to-length ratio. A 36” range unit is only 38” long
LRS-18- Spring Loaded LVIT
The spring-loaded LRS-18 has a ¾” OD aluminum body and is offered in ranges 12.5 to 100mm. Like the LR-19, the LRS-18 is ideal for OEM and factory automation applications where small size and low cost are a premium however the probe cannot be hard fixed to the measurand.
LR-19– Automation Duty LVIT
The LR-19 has a ¾” OD aluminum body and is offered in ranges up to 200mm. The LR-19 is ideal for OEM and factory automation applications where small size and low cost are a premium.
LR-27– Industrial Duty LVIT
The LR-27 series is more robust than the LR-19 and is offered in both a 1” OD aluminum or stainless steel housing. The LR-27 is also for industrial OEM and factory automation applications where the application or environment is too extreme for the LR-19.
LV-45– Extreme Duty LVIT
The LV-45 series units were designed to survive the most extreme environments being installed on bridges, train tracks, and off-road vehicles for construction and agriculture.
Sensor Connection
www.thesensorconnection.com
Filed Under: Sensor Tips
