  • Articles
  • 3D CAD Models
    • 2020 Winners
    • 2019 Winners
    • DIGITAL ISSUES
      • EE World Digital Issues
    • Motion Design Guide Library
    • Suppliers
  • COVID-19
LZ-19 Series LVIT linear position sensor
By Mike Santora | March 18, 2021
LZ-19 SS_0The LZ-19 Series of LVIT (Linear Variable Inductance Transducer) position sensors are contactless devices designed for use in factory automation or assembly machinery applications where space is a premium, as well as for external mounting on pneumatic cylinders to sense rod position. The LVIT is offered in nominal full scale ranges from 2.5 to 750 mm (0.1 to 30-in.) with an excellent stroke-to-length ratio. The sensor has a 19 mm (3/4-in.) outside diameter stainless steel or optional aluminum body with a 1m axial cable for I/O connections. The 6 mm (0.236-in.) diameter through-bore of an LZ-19 provides clearance for its 5.2 mm (0.2.00-in.) diameter, PVDF-sheathed moving rod, which is made of the same material as its housing. This through-bore feature also means that the sensor is not subject to damage from typical mechanical overstroking. Technical datasheets and the outline drawing are below
Features
  • Contactless operation prevents internal wear out from dithering or rapid cycling
  • LVIT Technology™ (Linear Variable Inductance Transducer)
  • Through-bore design eliminates mechanical overstroking
  • Full Scale ranges from 2.5 to 750 mm (0.1 to 30-in.)
  • Proprietary SenSet field adjustment range scaling
  • DC in / DC out operation with built-in electronics
  • Excellent stroke-to-body-length ratio
Alliance Sensors Group
alliancesensors.com
MOTION DESIGN GUIDES
  • Drilling rig OEM benefits from a PLC with edge computing technology: IIoT case study
  • The industry shift to smart electromechanical actuators
  • Commemorating a great entrepreneurial personality – Oskar Lapp at 100 – A pioneer for the future
  • SE motor – uncompromised motion performance
  • With virtual commissioning, commissioning time and prototype waste is reduced
  • Master Bond Supreme 10HT High strength, NASA low outgassing approved epoxy
Tweets by @DesignWorld
  • Articles
  • 3D CAD Models
    • 2020 Winners
    • 2019 Winners
    • DIGITAL ISSUES
    • Suppliers
  • COVID-19
