M12 connector with multi-position, lockable A-coding
By Mary Gannon | November 9, 2021
binder USA announced a new two-piece M12 circular connector that offers versatility with several special features including: square-flange housing for easy assembly, multi-position, and lockable A-coding that supports variable cable installation. The new connectors simplify secure sensor and actuator connections in applications such as factory automation and robotics.
BIN780_binder-M12-A_300-dpiThe connector’s innovative two-part design enables user friendly, safe assembly. The square-flange variants of binder’s 763 series consist of the metal flange housing and a contact carrier equipped with a lockable coding nose, which can be rotated in 45° increments. Additionally, the housing of the M12 single-wire model has the same drilling scheme as the M16 form factor, allowing users to switch between design sizes without having to adapt existing houses for field devices such as sensor/actuator boxes.
Highlights include:
  • Pins: 4, 5, and 8
  • Rated voltage: 30 V (4-pin), 60V (5-pin), and 250 V (8-pin)
  • Rated impulse voltage: 2500 V, 1500 V, and 800 V
  • Rated current: 4 A (3 A U) for 4- and 5-pin; 2 A (1.5 A UL) for 8-pin
  • Maximum wire gauge: 0.25 mm2 (AWG 24)
  • Contacts: single wire or solder
  • Protection rating: IP69
  • Operating temperatures: –40 ° to 70 °C in static condition
  • DIN EN 61076-2-101
binder USA
www.binder-usa.com
Filed Under: Connector Tips
Tagged With: binderusa
SV microwave 5G RF interconnect solutions available at Heilind Electronics
D-sub connectors: Everyone speaks of them incorrectly
Tool-less rectangular connectors boast 10,000 mating cycles
What is the common impedance of a twisted pair?
