Binder USA LP has released the series 813 M12 L-coded male cable connector. With Profinet-compliant plastic housing, this field-wireable connector is ideal for dc power supply applications up to 63 V/16 A. This connector is a panel-mount connector with single wires. (Standard wire length is 200 mm; other lengths are available upon request.) The screw locking mechanism meets the IEC 61076-2-111 standard.
Other product highlights include:
- Contacts: 4+FE
- Termination: single wires AWG 16
- Cable Outlet: 8.0 – 13.0 mm
- Rated Voltage: 63 V DC
- Rated Current: 16 A
- Mechanical Operation: >100 mating cycles
- Ingress Protection: IP67
- Not shielded
- Contact Plating: Au (gold)
Binder USA
www.binder-usa.com
Filed Under: Connectors (electrical) • crimp technologies
