Stewart Connector, a Bel group company, announces the addition of M12 X-code cable assemblies, supporting Ethernet connectivity up to 10 Gbps, making them ideal for both factory and industrial environments.
Stewart Connector’s M12 X-code cable assembly series includes 8-pin male M12 X-code plugs on both ends of the cable assembly, which allows these cable assemblies to establish an Ethernet connection without the use of RJ45 connectors. The male M12 X-Code connectors found in this series are IP67 rated and are terminated to a shielded cable with a TPE cable jacket, creating a robust assembly suitable for harsh environments. The M12 X-code cable assemblies provide reliable, high performing connections in industrial environments for Modbus, Ethernet, PROFINET, and EtherCAT.
Stewart Connector’s M12 X-code cable assemblies are in stock with Digi-Key, Mouser, and Newark.
Stewart Connector
belfuse.com
