Binder USA LP introduces the new M16-X connector, Series 415, an 8-contact male/female cable connector for high-speed data transmission with shielding to protect signal integrity, and IP67-rated ingress protection to withstand harsh environments. The M16-X has a rated voltage of 50 Vac/60 Vdc and is available with an optional female panel mount connector. The 8 gold-plated contacts have a current rating of 0.5 A. Applications include control and measurement, Industry 4.0 automation, and high-speed video imaging.
Summary of key features:
- Data transmission up to 10 Gbits/s
- Protective shielding
- Male/female cable connector
- Cable outlet 5.5 – 9 mm
- Female panel mount connector, front fastened
- Female panel mount connector with dip solder contacts
- Degree of Protection: IP67 in mated condition
- Rated Voltage: 50 Vac/60 Vdc
- Rated Current: 0.5 A
- Contact Plating: Au (gold)
Binder USA LP
www.binder-connector.us
Filed Under: Connector Tips
