M8 12-position female connector for factory automation, control systems
By Mary Gannon | March 18, 2020
BIN_binder USA_M8 12 connector_72 dpiBinder USA LP introduces the Series 718 M8 female connector, a 12-contact cable connector with an overmolded, hex screw connection and companion M8 male panel mount connector with single wires. The 12 gold plated contacts have a current rating of 1.0 A and rated voltage of 30 V. The M8 connector is ideal for use in applications including: factory automation, control systems, and electrical equipment requiring IP67 protection.
Key features of the M8 12 connector:
  • Cable sheath: PUR
  • Cable length: 2  or 5 m
  • Wire gauge: 28 AWG
  • Single lead PVC insulation
  • Bending radius: 5 x dia fixed, 10 x dia moving
  • Male panel mount connector with single wires, 26 AWG
  • Degree of protection: IP67 in mated condition
  • Rated voltage: 30 V
  • Pulse voltage: 800 V
  • Rated current: 1.0 A
  • Contact plating: Au (gold)
Binder USA LP
www.binder-connector.us
Filed Under: Factory automation, Connector Tips
Tagged With: binder
