Binder USA LP, launched the 818 series M8 D-coded field-attachable, molded cordset and panel mount connectors. The new 818 series is ideal for Industry 4.0 use in automation, sensors, test and measurement, and industrial Ethernet applications. The M8 D-coded connectors are available with four gold-plated contacts rated for 63 Vdc at 4 A, suitable for IP67 environments when mated.
The 818 Series meets IEC 61076-2-114, which allows use with other manufacturers’ connectors and sockets. The M8-D connectors are rated for CAT5 and suitable for PoE+ (Power over Ethernet) with data transmission of 100 MBits/s.
They are rated for temperature ranges from –25° to 85° C.
Binder USA LP
www.binder-connector.us
Filed Under: Connector Tips
