Pennsauken, NJ – Macro Sensors provides instructions on how to connect, install and calibrate the EAZY-CAL™ MME-1000 mini-module, the world’s most user-friendly LVDT signal conditioner. The video shows that a virtually effortless fingertip calibration routine can be used to field calibrate the EAZY-CAL signal conditioner in just mere seconds.
The EAZY-CAL™ MME-1000 mini-module saves time and money by eliminating repetitive null and span potentiometer adjustments associated with conventional analog based signal conditioners. Using two easily accessible front panel push buttons, calibrations are accomplished digitally in mere seconds. An intuitive, sequencing four LED status indicator guides the operator through the calibration process, and provides foolproof feedback to insure calibration integrity.
Macro Sensors’ video on the EAZY-CA: LVDT Signal Conditioner provides complete hands-on instruction on:
• Suggested calibration equipment
• Mechanical mounting
• Electrical input.out connector
• LVDT wirting
• Core Position
• Calibration routines
Macro Sensors
http://www.macrosensors.com/MME-1000.html
Filed Under: Sensors (position + other), Signal analyzers, Test + measurement • test equipment
