Line of magnetic T and C-slot cylinder sensors gives discrete output regarding the end-of-stroke position of pistons in pneumatic cylinders.
Compact, the non-contact sensors offer precise, repeatable switching behavior with defined and tested activation sensitivity. The sensor has a IP67-rated plastic housing and is available in NPN and PNP outputs, with cable or fly-lead connectors and a wide, 3 to 30 volt supply range.
Baumer Ltd
www.baumerelectric.com
Filed Under: Pneumatic equipment + components, SENSORS, TEST & MEASUREMENT
